[postgis-users] Insert geometry (error) using PL-SQL
David Blasby
dblasby at refractions.net
Mon May 12 11:55:22 PDT 2003
Rosangela Silva wrote:
> poligono := 'POLYGON(('||x1||' '||y1||','||x2||'
> '||y1||','||x2||' '||y2||','||x1||' '||y2||','||x1||' '||y1||'))';
> INSERT INTO sp VALUES (geoid,nome,GeometryFromText(poligono,-1));
> The error message is :
> ERROR: Function geometryfromtext(character varying, integer) does
> not exist
> Unable to identify a function that satisfies the given argument types
> You may need to add explicit typecasts
> My code is:
> geoid, nome, x1,y1,x2,y2 are variables of my function
This is because PGPSQL thinks poligono is a VARCHAR(n) variable.
Here's some suggestions:
1. change poligono into a TEXT type variable
2. change "INSERT INTO sp VALUES
(geoid,nome,GeometryFromText(poligono,-1));" into
(geoid,nome,GeometryFromText(geometry(poligono),-1));"
or
(geoid,nome,GeometryFromText(geometry(text(poligono)),-1));"
dave
