[postgis-users] postgis.sql is failing
Yurgis Baykshtis ybaykshtis at aurigin.com
Tue May 13 08:47:27 PDT 2003
I followed PostGIS Windows installation steps described here:
http://www.gasai.com/gisapps/WindowsHowTo.html
Everything was OK (cygwin, ipc, postgres, build) till the following
statement:
psql -U postgres -d myGISdb -f postgis.sql
I got the following errors
psql:postgis.sql:18: NOTICE:  ProcedureCreate: type histogram2d is not
yet defined
psql:postgis.sql:18: ERROR:  stat failed on file '$libdir/postgis.dll':
No such file or directory
And then just whole bunch of these:
psql:postgis.sql:23: ERROR:  current transaction is aborted, queries
ignored until end of transaction block
Then I tried to execute postgis.sql from the GUI tool (pgAdmin II) and
got the same error:
stat failed on file '$libdir/postgis.dll': No such file or directory
I appreciate if anybody could explain what should I do here.
