[postgis-users] Compound Index? (Integer + Spatial)
Yurgis Baykshtis
ybaykshtis at aurigin.com
Tue May 13 10:31:22 PDT 2003
Let me describe my problem using some fake sample for the simplicity
sake:
1. There is a database with two tables: maps and cities.
2. There are many maps and many cities in each map.
3. Each map has an integer map_id as a primary key
4. Each city has 2D location as POINT (x, y) and map_id it belongs to
5. The task is to find cities on a given map inside a given box:
SELECT FROM cities WHERE map_id = my_map_id AND location && '(x1,
y1, x2, y2)'::box
I am quite confused on how to build a proper index to make this query:
In 1-D world this would be a compound on map_id and location.
However, in PostreSQL and PostGIS I don't seem to be able to that.
So, when I use a spatial index on location, the query above will scan
through all maps and then use map_id = my_map_id as filter.
I can think of a three possible solutions:
1. Store each map in a separate DB
2. Store each map in a separate table.
3. Create a FAKE spatial column something like POINT (map_id, map_id)
and then build a compound index on this column and location:
SELECT FROM cities WHERE map_id && '(my_map_id, my_map_id)::box
AND location && '(x1, y1, x2, y2)'::box
But none of the above looks graceful.
Any idea on how to do this RIGHT?
