[postgis-users] POSTGIS DTED...
David Blasby
dblasby at refractions.net
Fri May 16 14:58:19 PDT 2003
Nick Ton wrote:
>Hi David,
>Thank you for your response about raster capabilities in PostGIS.
>It seems though that the CHIP data structure is for external programs
>developed using C or C++. Is there an equivalent Java version of the CHIP
>data structure? Also, I am a bit new to the GIS world, so I apologize
>for asking these silly questions:
You could convert the binary object into a JAVA object. Its fairly
simple, you just have to be very careful about ENDIAN concerns.
>Your email states that we can create a table using the following SQL
>command:
>CREATE TABLE myRaster (mychip chip, mybox geometry);
>a. Can I make this command call in the psql console enviroment once PostGis
>is installed?
>Or do I create a C program that first defines "mychip" data structure and
>then
>execute the SQL CREATE command in the same C program?
This "CREATE TABLE" command is pure SQL so you could run it in a psql
console once PostGIS is installed. It just creates a table that can
store CHIP data. You'll have to have another program (say C/C++/JAVA)
that actually creates the CHIP to stick in the table. You'll also want
another program (C/C++/JAVA) that takes the data out of the database.
In terms of the GEOMETRY datatype, you use shp2pgsql to put data into a
table, and pgsql2shp (or mapserver or JDBC...) to pull data out of the
database.
The CHIP type is pretty much just a bit bucket right now.
>b. If the latter is true, does this imply that I would have to invoke
>the update and query command from the same C Program. It's not clear to me
>that once I define the "mychip" data structure that any other external
>program
>would know the "mychip" data structure without having to redefine it.
Your external program will have to know what the CHIP datastructure
looks like so it can retreive them from the database and understand what
its been given.
I hope I'm making myself clear and answering your question. Here's an
example of what I mean. The mess of numbers is the actual chip.
ts_production=# \d hawaii_z4_1
Table "hawaii_z4_1"
Column | Type | Modifiers
mychip | chip |
mybox | geometry |
Indexes: hawaii_z4_gis
ts_production=# select * from hawaii_z4_1 limit 1;
580800000100000000000000DEAA2241000000802DF041410000000000000000000000005EAD224100000080CDF0414100000000000000000400000000000000CDCCCC3D6A000000200000002000000000000000883A500B0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
| SRID=-1;BOX3D(611695 2351195 0,612015 2351515 0)
