[postgis-users] Re: Error messages in PostGIS
strk strk at freek.keybit.net
Fri May 23 02:14:02 PDT 2003
rosangela.silva wrote:
> Hi,
> Thanks for information. Is everything ok now.
> But, if I've already created a spatial table with SRID = -1
> how can I convert this table (and all its elements) for SRID=4326?
> Is it possible??
Ok, this  sounds like something that needs a better user interface to
be done cleanly... AFAIK you have to hack it.
I'd try to update the geometry_column first (setting the SRID to the value
4326) and then update the  your spatial table using the setSRID() function
on the geometry column.
If the constraints dinamically check SRID from geometry_columns
table that should work.
--strk;
> Thanks
> Rosângela
>   > Hello all,
>   > I'm having two problems with PostGIS that I don't know
>   > how to solve them. I don't have much experience with database
>   > management. Could you help me, please?
>   > I DROP a table continent, but I don't DROP the spatial
>   > index before, and when I try to execute the sql again
>   > I receive the message below:
>   > $ psql -d geobusca -f continent.sql
>   > ERROR:  Relation 'continent' already exists
>   > psql:continent.sql:1: ERROR:  Relation 'continent' already exists
>   > ERROR:  Cannot insert a duplicate key into unique index geometry_columns_pk
>   > WARNING:  Error occurred while executing PL/pgSQL function addgeometrycolumn
>   > WARNING:  line 39 at execute statement
>   > psql:continent.sql:2: WARNING:  line 39 at execute statementng PL/pgSQL function
>   > psql:continent.sql:2: ERROR:  Cannot insert a duplicate key into unique index ge
>   > ometry_columns_pk
>   You need to delete from geometry_columns where f_table_name = 'continent'.
>   This is done automatically if you use dropGeometryColumn() befor dropping
>   the table.
>   > In other case, I delete a record from a spatial table and when I try to
>   > insert the same record again (with some changes) I received the message
>   > below:
>   > gisdb=# INSERT INTO wpt (wpt_waypointID, wpt_Name, the_geom) VALUES (9, 'TUN
>   > L25', GeometryFromText('POINT(-46.63758 -23.97345)', 4326));
>   > ERROR:  ExecInsert: rejected due to CHECK constraint "$1" on "wpt"
>   > gisdb=#
>   The CHECK constraint "$1" tries to force geometry SRID as specified in
>   the geometry_columns. You have removed the information related to
>   the specified table, thus the check is rejected.
>   > I'm using LATLONG/WGS84 and the wpt table is:
>   >                Table "public.wpt"
>   >      Column     |       Type        | Modifiers
>   >  wpt_waypointid | bigint            |
>   >  wpt_name        | character varying |
>   >  the_geom        | geometry          |
>   > Check constraints: "$1" (srid(the_geom) = -1)
>   >                    "$2" ((geometrytype(the_geom) = 'POINT'::text) OR (the_geom IS NULL))
>   > But I used the sintaxe bellow to create the table:
>   > CREATE TABLE wpt (wpt_waypointID bigint, wpt_Name varchar);
>   > SELECT AddGeometryColumn('geobusca','wpt','the_geom', 4326,'POINT',2);
>   > What can I have to do?
>   The creation sql seems good, but you  have to use DropGeometryColumn()
>   on the table before dropping the table itself.
>   If the problems also occurs immediatly after table creation (you never
>   tried to drop anything) try omitting the first parameter from
>   AddGeometryColumn.
>   --strk;
>   ----- Original Message -----
>   From: Rosangela Silva
>   To: postgis-users at postgis.refractions.net
>   Sent: Thursday, May 22, 2003 12:02 PM
>   Subject: Error messages in PostGIS
>   Hello all,
>   ometry_columns_pk
>   below:
>   gisdb=#
>                  Table "public.wpt"
>   Thanks
>   Rosângela.
