[postgis-users] Installing PostGIS
chodgson at refractions.net
Mon May 26 09:34:09 PDT 2003
Are you running cygwin using the .bat file (cygwin.bat?) or just by clicking on
the .exe? The batch file usually sets up your $PATH environment variable to let
you run the appropriate commands... if you can't figure out how to get your
environment set up, then you should be able to run the commands by using their
full path-name ie. C:\cygwin\bin\bunzip2
HTH.
Chris
Quoting Mike Leahy <mgleahy at fes.uwaterloo.ca>:
> Hello all,
> I´m a new user with PostGIS - I have yet to even successfully install it.
> I´ve been trying to use the directions in the refractions.net documentation
> section (at http://postgis.refractions.net/windows/WindowsHowTo.html).
> However, after I have installed Cygwin, and I open the cygwin command console
> (bash 2.05?), the first command I´m suppost to run to setup cygipc (bunzip2)
> simply returns "command not found". In fact, many of the commands are not
> found...even though there are corresponding exe files in the cygwin\bin
> folder. Clearly there is something I have not done that isn´t mentioned in
> these directions. Can anyone suggest what this might be?
> Kind regards,
> Mike
> This mail sent through www.mywaterloo.ca
> postgis-users mailing list
