[postgis-users] Update to where clause errors
Paul A Peters
papeters at fes.uwaterloo.ca
Tue May 27 08:36:38 PDT 2003
Thanks for the responses thus far. When I run shp2img I get the error
attached below. I ran though the wiki for postgis on the MapServer website
and I can access the database fine with that user, so I can't seem to narrow
the problem down there. I can't really make out too much from the error
message below. Maybe someone else will have some suggestions.
thanks,
Paul
C:\Inetpub\Scripts>shp2img -m C:\msapps\projects\Independencia.map -o
out.png prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual
query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(shape)),'NDR'),OID::text from gis_test
WHERE shape && setSRID('BOX3D(273346 8670666,281455 8677412)'::BOX3D,
find_srid('','gis_test','shape') )' <br><br>
Postgresql reports the error 'ERROR: Function 'force_2d(point)' does not
exist
Unable to identify a function that satisfies the given argument
types
You may need to add explicit typecasts
'<br><br>
More Help:<br><br>
Error with POSTGIS data variable. You specified '<check your .map
file>'.<br>
Standard ways of specifiying are : <br>
(1) 'geometry_column from geometry_table' <br>
(2) 'geometry_column from (<sub query>) as foo using unique <column
name> using SRID=<srid#>' <br><br>
Make sure you put in the 'using unique <column name>' and 'using
SRID=#' clauses in.
<br><br>For more help, please see
http://postgis.refractions.net/documentation.php
<br><br>Mappostgis.c - version of Nov 15/2002.
This is when I am using the .map file:
MAP
EXTENT 273346 8670666 281455 8677412
FONTSET "./Independencia/etc/fonts.txt"
IMAGECOLOR 255 255 255
IMAGEQUALITY 100
IMAGETYPE PNG
INTERLACE TRUE
SYMBOLSET "./Independencia/etc/symbols.sym"
SHAPEPATH "./Independencia"
SIZE 600 500
STATUS ON
TRANSPARENT FALSE
UNITS METERS
NAME "Independencia"
LEGEND
IMAGECOLOR 204 204 255
INTERLACE TRUE
KEYSIZE 18 12
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 89
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
OUTLINECOLOR 0 0 0
POSITION LL
STATUS ON
TRANSPARENT FALSE
TEMPLATE "c:/msapps/htdocs/mapedit/legend_template.html"
END
QUERYMAP
COLOR 51 100 255
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
REFERENCE
COLOR -1 -1 -1
EXTENT 272051 8670801 282750 8677277
IMAGE "./vista.gif"
OUTLINECOLOR 255 0 0
SIZE 100 60
STATUS ON
MARKER 0
MARKERSIZE 0
MINBOXSIZE 3
MAXBOXSIZE 0
END
SCALEBAR
BACKGROUNDCOLOR 204 204 204
COLOR 0 0 0
INTERLACE TRUE
INTERVALS 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
OUTLINECOLOR 0 0 0
POSITION LL
SIZE 300 8
STATUS ON
STYLE 0
TRANSPARENT FALSE
UNITS KILOMETERS
END
WEB
IMAGEPATH "c:/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
LAYER
CONNECTIONTYPE postgis
CONNECTION "user=Internet password=Manzana dbname=edumap host=localhost"
DATA "shape FROM gis_test"
FILTER "cod_mod > 0"
GROUP "Independencia"
NAME "Escuelas Primarias"
SIZEUNITS PIXELS
STATUS ON
TEMPLATE "ttt.html"
TOLERANCE 3
TOLERANCEUNITS PIXELS
TYPE POINT
UNITS METERS
CLASS
NAME "Escuelas"
COLOR 150 0 0
MAXSIZE 100
MINSIZE 1
SIZE 8
SYMBOL 2
END
END
END
Paul A Peters
http://www.fes.uwaterloo.ca/u/papeters
