[postgis-users] Update to where clause errors
Paul A Peters
papeters at fes.uwaterloo.ca
Tue May 27 13:06:21 PDT 2003
David:
I was indeed using the wrong point type, thanks for the help. I have gone
back and rebuilt my postgis installation and rebuilt my test database.
However, I am still getting the same error as before. So, I tried the "\d
gis_test" as suggested and I got the response attached. Thus, I am still
lost.
Thanks,
Paul
C:\postgresql\bin>psql -U Administrator edumap
Welcome to psql, the PostgreSQL interactive terminal.
Type: \copyright for distribution terms
\h for help with SQL commands
\? for help on internal slash commands
\g or terminate with semicolon to execute query
\q to quit
edumap=# \d gis_test
Table "gis_test"
Column | Type | Modifiers
gid | integer |
cod_mod | character varying |
the_geom | geometry |
Check constraints: "$1" (srid(the_geom) = -1)
"$2" ((geometrytype(the_geom) = 'POINT'::text) OR
(NULL::geom
etry = the_geom))
edumap=# \q
C:\postgresql\bin>
Again, the error I get when using shp2img is:
C:\Inetpub\Scripts>shp2img -m c:\msapps\projects\Independencia.map -o
prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query)
stat
ement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(forc
e_2d()),'NDR'),OID::text from WHERE && setSRID('BOX3D(273346
8670666,281455 86
77412)'::BOX3D, find_srid('','','') )' <br><br>
Postgresql reports the error 'ERROR: parser: parse error at or near "WHERE"
'<br><br>
More Help:<br><br>
Error with POSTGIS data variable. You specified '<check your .map
file>'.<
br>
Standard ways of specifiying are : <br>
(1) 'geometry_column from geometry_table' <br>
(2) 'geometry_column from (<sub query>) as foo using unique <column
nam
e> using SRID=<srid#>' <br><br>
Make sure you put in the 'using unique <column name>' and 'using
SRID=#'
clauses in.
<br><br>For more help, please see
http://postgis.refractions.net/documentation.p
hp
<br><br>Mappostgis.c - version of Nov 15/2002.
C:\Inetpub\Scripts>
My layer definition is:
LAYER
CONNECTIONTYPE postgis
CONNECTION "user=Internet password=Manzana dbname=edumap host=localhost"
DATA "the_geom FROM gis_test"
GROUP "Independencia"
NAME "Escuelas Primarias"
SIZEUNITS PIXELS
STATUS ON
TEMPLATE "ttt.html"
TOLERANCE 3
TOLERANCEUNITS PIXELS
TYPE POINT
UNITS METERS
CLASS
NAME "Escuelas"
COLOR 150 0 0
MAXSIZE 100
MINSIZE 1
SIZE 8
SYMBOL 2
END
END
Paul A Peters
http://www.fes.uwaterloo.ca/u/papeters
-----Original Message-----
From: David Blasby [mailto:dblasby at refractions.net]
Sent: May 27, 2003 11:15 AM
To: papeters at alumni.uwaterloo.ca; PostGIS Users Discussion
Subject: Re: [postgis-users] Update to where clause errors
Paul A Peters wrote:
> C:\Inetpub\Scripts>shp2img -m C:\msapps\projects\Independencia.map -o
> out.png prep_DB(): Query error. Error executing POSTGIS DECLARE (the
> actual
> query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d(shape)),'NDR'),OID::text from gis_test
> WHERE shape && setSRID('BOX3D(273346 8670666,281455 8677412)'::BOX3D,
> find_srid('','gis_test','shape') )' <br><br>
> Postgresql reports the error 'ERROR: Function 'force_2d(point)' does
> not exist
> Unable to identify a function that satisfies the given
> argument types
> You may need to add explicit typecasts
> '<br><br>
The message : Function 'force_2d(point)'
indicates you're probably using the built-in postgresql datatypes NOT
PostGIS types. How did you get your data into the database?
You can test this by opening up psql and typing:
\d gis_test
If the shape type is 'point' you're using the old postgresql datatypes.
If it says 'geometry' you're using a PostGIS type - unfortunately this
would indicate that something is wrong with your installation.
dave
