[postgis-users] RV: Insert point in postgis
chodgson at refractions.net
Thu May 29 14:30:14 PDT 2003
You probably need to use php-mapscript to do this, but it's not very hard to do.
Use an image-map in an html form to capture the coordinates of the click inside
of the map image. Do a little bit of math using the image size and the map
extents to calculate the map coordinates of the click, and then insert those
coordinates, along with the related data (name, address, etc) into the database
using an SQl query in PHP.
There are examples of SQL for inserting a geometry into the PostGIS manual at
http://postgis.refractions.net/docs/x398.html#AEN401
Examples of the WKT for a point are at:
http://postgis.refractions.net/docs/c282.html
Have a go at it!
Chris
Quoting Luz Brigitte <luzbrigitte at hotmail.com>:
> I´m sorry, maybe that I don´t explain well.
> The idea is to know like I can insert a point in an application of
> mapserver and that inmediately with this information modifies my
> postgres database.
> Or somebody knows anyone code lines php in which I request the
> coordinates x,y and in addition she captures information on that point
> in my database, for example : name, address, phone, etc.
> Brigitte P.
> Colombia
> I am not sure what two actions you are referring to.
> What needs to happen in mapserver? Mapserver only display the data for
> your
> map. I assume the data for your map is stored in a table in PostGIS, so
> if you
> insert a new point into your PostGIS table, it will be displayed by
> mapserver.
> What else do you what to happen at the same time? If you want to insert
> other
> data into PostGIS at the same time (perhaps a row into another,
> non-spatial
> table) then you can use SQL transactions to do so - look them up in the
> PostgreSQL documentation.
> Chris
> <http://lw12fd.law12.hotmail.msn.com/cgi-bin/compose?curmbox=F000000001&
> a=da28bbaf5a0f184d9fac6c11d1d66787&mailto=1&to=luzbrigitte at hotmail.com&m
> sg=MSG1054234822.57&start=1105925&len=17577&src=&type=x>
> > Hi, somebody knows like I can insert a point within a map in mapserv
> and
> > that of once this is added to a table in postgresql.
> > For example I have a customer´s map and I want add a customer but I
> need
> > both of this actions to occurr in tandem (Mapserv and Postgis).
> > I work with mapscript - php in Mapserver 3.6 and PostgreSQL 7.2.2 and
> > postgis 0.6.3.
> > Thanks a lot for your help.
> > Brigitte P.
> > Colombia
