[postgis-users] postgis/postgrsql/geos
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Mon Nov 3 07:33:30 PST 2003
Hi Mike,
As I understand it, installing GEOS only installs the library files
required to use the new geometry functions. To use the new functions in
postgresql, you will need to use the latest CVS version of PostGIS and
alter the makefile to ensure that it has been compiled with support for
the GEOS functions. Finally, you will have to re-run the postgis.sql
script into the database to allow postgresql to see the new function
definitions, so it may be a good idea to try this in a new database and
work from there.
Hope this helps,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Elstermann, Mike
> Sent: 03 November 2003 14:26
> To: 'postgis-users at postgis.refractions.net'
> Subject: [postgis-users] postgis/postgrsql/geos
> hi,
> i have a problem :-(
> i'm working with suse 8.2 , postgresql 7.3.3, postgis 0.7.5
> ... wonderful
> now i want to use some spatial functions: intersects, ....
> thats why i have installed GEOS (./configure, make, make
> install) ... successfully :-)
> but when I start a select with spatial function it doesn't works ???
> for example:
> select disjoint(\'LINESTRING(0 0,0 0)\'::geometry,
> \'LINESTRING(0 0,0 1)\'::geometry );
> Warning: pg_exec() query failed: ERROR: Function disjoint(geometry,
> geometry) does not exist Unable to identify a function that
> satisfies the given argument types You may need to add
> explicit typecasts
> where is the errors?
> ::: mfg. Mike Elstermann [mikeE.], Teamleiter GIS/RIS, e-Solutions
> ::: IT-Consult Halle GmbH, Bornknechtstraße 5, 06108 Halle (Saale)
> ::: Sitz: Große Nikolaistraße 8
> ::: Tel.: +49 345 221 4237, Fax: +49 345 221 4236, mobil: +49
> 160 71 545 02
> ::: mike.elstermann at itc-halle.de ::: http://www.itc-halle.de
> ::: GeoDaten Online? -> http://www.itcgis.de
> postgis-users mailing list postgis-users at postgis.refractions.net
