[postgis-users] Create View with PostGis table
opengis
opengis at libero.it
Wed Nov 12 06:24:17 PST 2003
> I'm confused not sure if you put in the right view definition or a typo or
> what, but the view definition you provided is called
> only_pg_view
> But the view you are trying to use is called
> only_pg_land_use
> Those 2 should match correct?
Thanks but it is only a cut & past mistake, the problem is always data type
(geometry) lose in CREATE VIEW
opengis (at) libero (dot) it
AOL: open2gis
