[postgis-users] Problems with installing on Cygwin
Will Shaw
wshaw at neo.tamu.edu
Wed Nov 12 14:44:55 PST 2003
Hello List,
I'm having a little problem with installing postgresql for use with the new
GEOS/PostGIS.
Installation:
Windows XP
Cygwin 1.5.5-1
Postgresql 7.3.4-2 (source from Cygwin)
I ran the configure script like this:
$ LDFLAGS=-lstdc++ ./configure --enable-multibyte --with-CXX --prefix=/usr
--sysconfdir=/etc --docdir=/usr/doc/postgresql-$version
And then did a make and make install
The make apparently worked fine, it gave me the message "Postgresql made
successfully" and there were no apparent problems with make install.
I then ran
$ ipc-daemon2 &
$ initdb -D /usr/share/postgresql/data
And got the following output:
The files belonging to this database system will be owned by user
"postgres". This user must also own the server process.
The database cluster will be initialized with locale C.
Fixing permissions on existing directory /usr/share/postgresql/data... ok
creating directory /usr/share/postgresql/data/base... ok creating directory
/usr/share/postgresql/data/global... ok creating directory
/usr/share/postgresql/data/pg_xlog... ok creating directory
/usr/share/postgresql/data/pg_clog... ok creating template1 database in
/usr/share/postgresql/data/base/1... IpcSemaphore
Create: semget(key=1, num=17, 03600) failed: Function not implemented
initdb failed.
Just to make sure there was nothing wrong with ipc-daemon2, I installed the
binaries using the Cygwin setup program and tried to initialize the database
again and it worked. Does anyone know what the problem might be? Any help
would be greatly appreciated.
Thanks
Will Shaw
PhD Candidate
Texas A&M University
