[postgis-users] How to export a table including polygon & multipolgon typed geometries to a shapefile
Paul Ramsey
pramsey at refractions.net
Fri Nov 14 11:04:19 PST 2003
create table dumptable as select thegeomyouwant,column,column2 from
theoldtable;
then dump the dumptable.
P
Hisaji Ono wrote:
> Hello.
> After GeomUnioning multipolygons by grouping a given field, both polygon &
> multipolgon typed geometries were generated in new table.
> I tried to execute pgsql2shp to generate a shapefile.
> However pgsql2shp said following error message.
> ERROR: Cannot have multiple geometry types in a shapefile.
> Use option -t(unimplemented currently,sorry...) to specify what type of
> geometry you want dumped
> Could you tell me this resolution?
> Regards.
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
