[postgis-users] Re: [geos-devel] Help with Compiling
strk
strk at keybit.net
Tue Nov 25 00:41:56 PST 2003
Did you install the geos library ( I'm afraid you have to ) ?
What system are you on ? For unix based os you'll have to run
ldconfig(8) afterwards.
--strk;
gisrookie wrote:
> Hello strk
> Thank you for your reply. I am trying to compile CoordinateListsExample.cpp
> from the examples folder and the following are the first lines of errors
> tmp/ccCrvVPd.o: In function main
> tmp/ccCrvVPd.o(.text+0x51): undefined reference to
> 'geos::CoordinateListFactory::internalFactory'
> tmp/ccCrvVPd.o(.text+0x59): undefined reference to
> tmp/ccCrvVPd.o(.text+0x92b): undefined reference to
> tmp/ccCrvVPd.o(.text+0x948): undefined reference to
> tmp/ccCrvVPd.o(.text+0x950): undefined reference to
> and all the other errors which are the same but change in the (.text+***)
> field. I would be thankful if you can help with the above.
> Thanks
> Sunil
> >From: strk <strk at keybit.net>
> >To: Rookie GIS <gisrookie at hotmail.com>
> >CC: GEOS Development List <geos-devel at geos.refractions.net>
> >Subject: Re: [geos-devel] Help with Compiling
> >Date: Tue, 25 Nov 2003 00:29:27 +0100
> >gisrookie wrote:
> > > Hello
> > > I have downloaded and installed the Geos library on my computer and
> >tried to
> > > compile one of the examples given in the same, but get a bunch of
> >errors. I
> > > think I need to compile the same by linking the libraries at the command
> > > line. I would be thankful if anyone can help me with the above.
> > > Thanks in advance
> > > Sunil
> >Can you tell which examples did you try to compile and what are the first
> >lines of the errors you get ?
> >--strk;
> _________________________________________________________________
> >From the hottest toys to tips on keeping fit this winter, youll find a
> range of helpful holiday info here.
> http://special.msn.com/network/happyholidays.armx
