[postgis-users] Will someone compile PostGIS 0.8.0 and PostgreSQL 7.4 for Win32 and want to share it?
Steffen Macke
sdteffen at web.de
Tue Nov 25 02:27:27 PST 2003
> You have to make GEOS throw an exception and see if it kills the backend.
> If it does you need to link against libstc++, if you get an error message
> (ERROR severity in pgsql) everything is ok. Trying to GeomUnion a collection
> should throw an exception, you can try that.
dcmms=# select geomunion('GEOMETRYCOLLECTION(LINESTRING(1 1,0 0),POINT(0
0)');
geomunion
SRID=-1;GEOMETRYCOLLECTION(LINESTRING(1 1,0 0),POINT(0 0))
(1 row)
No error message, but the backend is still alive. Should the backend die
randomly? I get the same result on SuSE 8.2, PostgreSQL 7.3.2.
Steffen
