[postgis-users] FW: postgis.sql
Tyler Mitchell TMitchell at lignum.com
Thu Oct 16 10:05:39 PDT 2003
Do you mean that the postgis.sql file is not from the same code base from
which libpostgis.so was "installed"?
Anthony, are you getting the postgis.sql file from the same location as the
libpostgis.so.0.7?  Are there other versions of that library on your
system?
postgis-users-bounces at postgis.refractions.net wrote on 10/16/2003 09:59:21
AM:
> It seems like the postgis.sql you are installing and the libpostgis you
> are linking to are not in sync.
> Anthony Agoro (C) wrote:
> > Hello guys,
> > Many thanks for your help.
> > I managed to locate the libpostgis.so.0.7 in
> > /usr/local/pgsql/postgresql-7.3.4/contrib/postgis-0.7.3
> > I modified the postgis.sql file manually to point to my libpostgis
> > and ran make install again from my postgis directory.
> > Please see the log files
>        __
>       | Paul Ramsey
>       | Refractions Research
>       | Email: pramsey at refractions.net
>       | Phone: (250) 885-0632
>       \_
> postgis-users mailing list
