[postgis-users] FW: postgis.sql
Paul Ramsey pramsey at refractions.net
Thu Oct 16 10:09:11 PDT 2003
It is calling a C function in the library which does not exist, possibly
  because the library was compiled with gist_estimate commented out.
Basically it sounds like somebody hacked together an install on the
quick, but did not document what they did. Or as you say the sql and the
lib could be from different code bases, or more likely, different
compile configurations.
P.
Tyler Mitchell wrote:
> Do you mean that the postgis.sql file is not from the same code base from
> which libpostgis.so was "installed"?
> Anthony, are you getting the postgis.sql file from the same location as the
> libpostgis.so.0.7?  Are there other versions of that library on your
> system?
> postgis-users-bounces at postgis.refractions.net wrote on 10/16/2003 09:59:21
> AM:
>>It seems like the postgis.sql you are installing and the libpostgis you
>>are linking to are not in sync.
>>Anthony Agoro (C) wrote:
>>>Hello guys,
>>>Many thanks for your help.
>>>I managed to locate the libpostgis.so.0.7 in
>>>/usr/local/pgsql/postgresql-7.3.4/contrib/postgis-0.7.3
>>>I modified the postgis.sql file manually to point to my libpostgis
>>>and ran make install again from my postgis directory.
>>>Please see the log files
>>       __
>>      | Paul Ramsey
>>      | Refractions Research
>>      | Email: pramsey at refractions.net
>>      | Phone: (250) 885-0632
>>      \_
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
       __
      | Paul Ramsey
      \_
