[postgis-users] question with loading postgis.sql
Paul Ramsey
pramsey at refractions.net
Thu Oct 16 19:44:10 PDT 2003
The most important notice is the first one, which should tell you
(approximately) which SQL statement failed. Where does the output
transition from successes to failures?
P
On Thursday, October 16, 2003, at 05:29 PM, Nelson Tong wrote:
> I have just successfully compiled and installed postgis with
> PostgreSQL7.2.2 and redhat 7.3 (Thanks alot for your help, Darren and
> Chris).
> As following the installation documentation, I enabled PL/pgSQL, but
> when I tried to load the PostGIS object and funtions defintion with
> postgis.sql (psql -d [databasename] -f postgis.sql], I got the
> following erros:
> NOTICE: current transaction is aborted, queries ignored until end of
> transactio
> n block
> *ABORT STATE*
> transactio
> n block
> transactio
> n block
> *ABORT STATE*
> transactio
> n block
> transactio
> n block
> *ABORT STATE*
> transactio
> n block
> transactio
> n block
> *ABORT STATE*
> transactio
> n block
> transactio
> n block
> *ABORT STATE*
> COMMIT
> When I checked the pgsql database to which I tried to load
> 'postgis.sql', no fuction has actually been created. Then I decided
> to use the test script in 'postgis.sql' to see if PL/PgSQL is
> installed in the database, the result of the query was:
> message
> You must install PL/PgSQL before running this SQL file,
> or
> you will get an error. To install PL/PgSQL run:
> createlang plpgsql <dbname>
> (1 row)
> So I ran 'cretelang plpgsql <dbname>' (which I have already done
> before I attempted to load pstgis.sql), pgsql told me that:
> 'createlang: language "plpgsql" is already installed in database
> <dbname>'
> I tried to change USE_PG72=0 line to USE_PG72=1 (in the Makefile)
> since this is listed as one of the suggestions under the Common
> Problems heading of the documentation, But I couldn't find there is
> such a line in the Makefile.
> Has anyone have similar problems when try to load the file
> 'postgis.sql'?
> S.T.
> _________________________________________________________________
> Never get a busy signal because you are always connected with
> high-speed Internet access. Click here to comparison-shop providers.
> https://broadband.msn.com
> postgis-users mailing list
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
