[postgis-users] Query not using index - why not?
Andrew Edmondson
a.edmondson at eris.qinetiq.com
Fri Oct 24 06:31:11 PDT 2003
I have a table called location (see definition below) - with a longlat column.
I want to select everything from location where longlat is within 50000 meters of a given point.
This query takes ages - and the EXPLAIN says it's doing a scan, rather than using the index.
Any ideas on how I can make it use the, or another better, index?
Thanks,
-Ed
<TABLE DEFINITION - INCLUDING INDEXES>
Table "public.location"
Column | Type | Modifiers
location_id | integer | not null default nextval('public.location_location_id_seq'::text)
longlat | geometry |
Indexes: location_location_id_key unique btree (location_id),
location_location_idunique_idx unique btree (location_id),
location_longlat_idx gist (longlat)
Check constraints: "$1" (srid(longlat) = 4278)
"$2" ((geometrytype(longlat) = 'POINT'::text) OR (longlat IS NULL))
</TABLE DEFINITION>
<QUERY>
EXPLAIN SELECT *, DISTANCE_SPHEROID('SRID=4278;POINT(120.4 14.583333)', longlat, 'SPHEROID[\"Airy_1830\",6377563.396,299.3249646]') AS distance FROM location WHERE DISTANCE_SPHEROID('SRID=4278;POINT(120.4 14.583333)', longlat, 'SPHEROID[\"Airy_1830\",6377563.396,299.3249646]') < 50000;
QUERY PLAN
Seq Scan on "location" (cost=0.00..25.00 rows=333 width=40)
Filter: (distance_spheroid('SRID=4278;POINT(120.4 14.583333)'::geometry, longlat, 'SPHEROID("Airy_1830",6377563.396,299.3249646)'::spheroid) < 50000::double precision)
(2 rows)
</QUERY>
Andrew Edmondson
PGP Key: http://search.keyserver.net:11371/pks/lookup?op=get&search=0xCEE814DC
PGP Fingerprint: 7B32 4D1E AC4F 29E2 9EAA 9550 1A3D BBA4 CEE8 14DC
