[postgis-users] Insert performance issues
Nicolas RIBOT nri at scot.cnes.fr
Sun Oct 26 10:21:28 PST 2003
Hi Dave,
We also noticed very good performance on Postgis on our previous
databases.
That's why I sent this email this time: i wanted to understand the
reason of the bottleneck.
As a first clue, seven indices on the same table seems to be too much
> Could you send me your SQL script (and how to create the
> table it will
> be inserting into)?
Yes, I could send it to you, but the actual table already contains 140
000 polygons. The SQL scripts is about 300 Mb.
Inserting/updating/deleting data in this table seems to be the problem,
as I saw that on a fresh, empty table, inserts are pretty fast.
> Also, you shouldnt be able to fit a 100,000 point polygon
> into a 1MB SQL
> file.
You are right. The 1mb file I was talking about contained only "small"
polygons". Big ones fit in 6 to 10 Mb text files
Thanx
Nicolas
