[postgis-users] Insert performance issues
Charlton Purvis
cpurvis at asg.sc.edu
Mon Oct 27 10:58:32 PST 2003
Sorry to have joined the thread so late. Good chance that I've missed
the crux of the messages.
But I read through the thread, and your initial questioned seemed to be
centered around insert performance. And I am intimate w/ that beast.
I'd HIGHLY recommend that you use the pgsql COPY command instead of lots
of inserts. It reduced my insert time exponentially from something like
12 hours to 5 minutes for about 5 million records. Kind of crazy, eh?
That is, if you can lock the table you're updating w/o effecting your
production system. Also, removing all indices on the table before
copying helps, too. Then rebuild and analyze them once your table is
populated.
Charlton
