[postgis-users] Insert performance issues
Gerry Creager N5JXS
gerry.creager at tamu.edu
Tue Oct 28 06:38:46 PST 2003
Excellent idea. Thanks for the paradigm shift. The use of hourly, or
daily, tables is one thing I'd briefly considered but not put sufficient
time into. You've just crystallized its use.
I can do a much shorter, 48 hour history and dump a day's worth of data
into the archive db. That'd give me real fast queries and allow me to
keep solely unique historic data (archival info _is_ important).
We're branching into models, especially EPA-based ozone mapping and
modelling, and looking at sea-breeze influence. Hence, we're going to
have to become more efficient.
Thanks!
gerry
Charlton Purvis wrote:
> Hey, Gerry:
> Good. So I wasn't too far off base. A rare occurrence, these days.
> I'm working w/ two type of data: (1) near real-time oceanographic and
> meteorological data, and (2) model hindcasting and forecasting. So you
> can bet your bottom dollar that real-time snags is important. It's
> farther along than "experimental", but it can stand to endure some
> revisions. However, I think our solution works well for our beast.
> It's likely that my (1) matches your situation more readily. I update
> my stuff on an hourly basis, namely because the buoys and weather
> stations across the SE all have hourly updates as their lowest common
> denominator. The good news for me is that these hourly inserts are
> relatively speedy and don't require for me to lock the table. Yes, just
> one table. And I don't use the copy command, just good old inserts.
> This is where it differs from my (2).
> The modeling stuff (2) is a daily update, and it is mucho data that uses
> the solution I presented to you below. But w/ a twist. Since I know
> that my stuff is visible in hourly increments, e.g. show me the hourly
> forecast for the next 24 hours across the SE Atlantic, when I am
> inserting the newest forecast in the evening, I create a separate table
> for each hour. Each hourly table consists of about 25k records. Not
> too bad, but when you multiply that by several days, several models, and
> several variables, it's a really big deal. Creating these hourly tables
> results in very, very speedy query returns since I take care of the
> logic up front about which table to choose based on which hour the user
> wants to see. It's likely that I could have gotten around this w/
> multiple column indexing, but I couldn't get a geom to gel w/ other
> column types.
> Anyway, just my food for thought. I'd say that if you could find a
> reliable way to divide your data time-wise, consider separating the data
> out into different time-based tables. It's great when you start
> considering putting different time chunks on different disks or
> databases or boxes, and creating cached images is a snap and doesn't
> muck up performance if you've got everything placed and tuned correctly.
> Just my thoughts.
> Charlton
>>-----Original Message-----
>>From: Gerry Creager N5JXS [mailto:gerry.creager at tamu.edu]
>>Sent: Tuesday, October 28, 2003 8:38 AM
>>To: PostGIS Users Discussion
>>Subject: Re: [postgis-users] Insert performance issues
>>So: I'm doing a whole slew of inserts (OK, COPY's) on a frequent
> basis,
>>say, every 6 minutes. I can lock the table, take down the index, do
> the
>>COPY, unlock the table, reindex. Doesn't take _too_ long 'til I get
> to
>>the new index. I've got to be able to snag those data in almost real
>>(read: "as inserted") time for display on my Mesonet site.
>>I'm concerned that your solution, while we've found it to be the
>>fastest, too, will adversely affect our SELECT performance and
> plotting.
>>Thanks,
>>Gerry
> postgis-users mailing list
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
