[postgis-users] Updating geometries with JDBC
Chris Holmes
cholmes at openplans.org
Tue Oct 28 07:50:15 PST 2003
Hi, I was wondering if anyone had experience using JDBC's ResultSet's
update methods with postgis geometries. I'm using jts geometries in my
client code, and would like to use updateString or updateObject to update
a current result set to the new geometry.
I've tried updateString(3, GeometryFromText( wkt-string, -1))
and updateString(3, SRID=-1;wkt-string). Both resulted in sql error:
Relation 'road' does not have attribute 'astext'. I also tried
updateObject with similar results.
I then tried using the name of the column: 'the_geom', and then I got
errors that said: The column name the_geom not found.
Has anyone encountered errors like this before, and might know a
workaround? In the past I've just constructed sql statements directly and
executed them, using GeometryFromText, and that always worked fine. But
we're chaning our api around, and it makes things _much_ cleaner if I can
use the update result set statements. If there's an easy way to turn the
objects directly into the postgis objects I'd be open to that as well, but
I'd need some pointers how to go about doing so.
thanks,
Chris
