[postgis-users] Fast collect() aggregate
strk
strk at keybit.net
Tue Oct 28 08:59:48 PST 2003
I've made the fast collect() aggregate.
It uses geom_accum() as state transaction function
and a newly made collect_garray() as final function.
Running time to collect 8109 objects in 8102 geometries
goes from 32 minutes to less then 5 minutes.
I strongly belive no much more memory is used by new implementation
since array-accumulated geometries will be (in this case) bigger
then result collection by 8102 geometry headers (number of geoms in input).
Memory usage evaluation - though - is not easy with postgresql.
Anyway: here is how to enable 'fastcollect':
If you did not already do it for 'fastunion' create the geom_accum() function:
CREATE FUNCTION geom_accum (geometry[],geometry)
RETURNS geometry[]
AS '$libdir/../libpostgis.so.0.8'
LANGUAGE 'C';
Create the new collect_garray function and the aggregate:
CREATE FUNCTION collect_garray (geometry[])
RETURNS geometry
LANGUAGE 'C';
CREATE AGGREGATE fastcollect (
sfunc = geom_accum,
basetype = geometry,
stype = geometry[],
finalfunc = collect_garray
PS: remember to get in sync with CVS.
--strk;
