[postgis-users]
Menke, Kurt
kmenke at edac.unm.edu
Tue Sep 9 14:50:53 PDT 2003
I am trying to familiarize myself with POSTGIS syntax and am hitting some
barriers. I'm sure there is something basic I am missing. Any help would
be greatly appreciated
1) Is Geometry still a valid data type? I am working on a POSTGIS tutorial
and if I use the SELECT command below
SELECT AddGeometryColumn ( 'db', 'table', 'field', -1, 'GEOMETRY', 2 ) ;
I get:
Invalid Type name - valid ones are: GEOMETRY, GEOMETRYCOLLECTION, POINT,
MULTIPOINT, POLYGON, MULTIPOLYGON, LINESTRING, MULTILINESTRIN
2) I hit another roadblock when trying to use the shp2pgsql command.
When I try to dump a shapefile into a new tabel using:
./shape2pgsql -D db /var/www/cgi-bin/atlas/data/states_nlam.shp states db
I get a series of coordinates printing to the screen but the table is not
created. What am I doing wrong?
Thanks,
Kurt
Kurt A. Menke
GIS Analyst
Earth Data Analysis Center
The University of New Mexico
Bandelier West, Room 111
Albuquerque, NM 87131-6031
(505)277-3622 ext. 239
Fax (505)277-3614
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030909/afc68de9/attachment.html>
