[postgis-users] ": can't parse "ne 1, pg_atoi: error in " & empty strings in shp2pgsql output...
Mike Leahy mgleahy at fes.uwaterloo.ca
Sat Sep 13 17:24:36 PDT 2003
Hello all,
I’ve just installed Cygwin (on WinXP) and compiled the latest available
versions of PostgreSQL/PostGIS.
When I run a COPY query to import data from a tab-separated DOS-text file I
get the following message:
Sometimes it’s followed by a number.  I know this is caused because my data
files are windows text files - when I convert the files to UNIX text files
using UltraEdit32, it works fine (though I now have to specify that empty
strings are null values).  I know that this problem is specifically to do with
the PostgreSQL - but I'm just curious if anyone on this list knows of an easy
fix that doesn’t require converting all my files...perhaps a setting in Cygwin
or something (I’ve already tried installing it with the DOS file setting, and
I’ve tried compiling PostgreSQL/PostGIS with all the fopen or popen commands
with the t argument for text).
My other problem, more relevant to PostGIS, is that in some cases when I
import a spatial table from an SQL file which I’ve created using the shp2pgsql
command, if there are null values in numeric columns it writes two single
quotes in the insert statement (i.e., an empty string rather than a NULL
value).  I know this is a problem for the newer version of PostgreSQL (i.e.,
in the newer versions, an empty string can’t be used as a null value for a
numeric column).  I looked at the code in shp2pgsql.c, but I really can’t see
where it’s deciding whether to put NULL or ‘’ for an empty record in a numeric
column.  It doesn’t seem to have any problem identifying null strings (i.e.,
there are NULL values in the file, but only in the string columns).  Perhaps
the actual problem is that the NULL/empty strings have been reversed, where
empty strings are getting NULLs, and empty numbers are getting ‘’s ...  This
is a bigger pain to fix, because I have to replace all ‘’ with NULL in my sql
file - meaning that any string columns that had empty strings now have null
values instead.  I don’t think that will affect me for my work, but it’s
probably better to keep empty strings when possible.
I don’t suppose anyone would have any updated code for shp2pgsql that reflects
this issue?
Kind regards,
Mike
This mail sent through www.mywaterloo.ca
