[postgis-users] PostGIS with Mapserver/Mapscript 4.0
Norman Vine nhv at cape.com
Tue Sep 16 02:01:29 PDT 2003
Mike Leahy writes:
> I apologize if I'm asking what may be an obvious question, but can you tell me
> where I would find the version of PostGIS that you plan to comit these changes
> to?  Is it the CVS download on the postgis.refractions.net downloads page?  If
> so, I was not able to compile that version (the results from my attempt are
> below).
> Sorry if I'm way off here - perhaps I just don't know exactly how to use CVS
> version...what would I have to do differently compared to compiling 0.7.5?
> Output from compiling CVS source code:
> gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations -g -fexceptions   -
> I. -DFRONTEND -DSYSCONFDIR='"/etc/postgresql"'
> -DUSE_VERSION=73 -I/usr/local/include/geos -DUSE_GEOS -I/usr/local/include -
> DUSE_PROJ  -DUSE_STATS  -I../../src/include   -c
> -o postgis_transform.o postgis_transform.c
> postgis_transform.c:49:22: projects.h: No such file or directory
The compiler can not find the Proj4 headers.
Have you installed it ?
To PostGIS Readme maintainer:
Perhaps we should add the Proj4 URL to the Readme file ?
http://www.remotesensing.org/proj
HTH
Norman
