[postgis-users] regarding Makefile errors and my own question
pw
p.willis at telus.net
Wed Sep 24 14:23:49 PDT 2003
Hello,
It is not clear in the installation instructions/documentation how to
actually build postgis.
The *REAL* installation information is found at:
http://postgis.refractions.net/README.postgis.txt
The README discloses that this is meant to be added to a
postgresql build:
INSTALLATION:
PostGIS is compatible with PostgreSQL 7.1 and above.
To install the module, move this directory to the "contrib" directory of
your
PostgreSQL source installation. Alternately, edit the "top_buildir" in
the
Makefile and point it at your PostgreSQL source tree. You must have a
PostgreSQL source tree, and you must have run succesfully built and
installed
it for this to work.
Hope this helps someone.
Peter
