[postgis-users] regarding Makefile errors and my own question
Paul Ramsey pramsey at refractions.net
Wed Sep 24 14:38:21 PDT 2003
Fair enough. Which fake documentation led you to believe something else,
it would be good to change that.
P.
pw wrote:
> Hello,
> It is not clear in the installation instructions/documentation how to
> actually build postgis.
> The *REAL* installation information is found at:
> http://postgis.refractions.net/README.postgis.txt
> The README discloses that this is meant to be added to a
> postgresql build:
> INSTALLATION:
> PostGIS is compatible with PostgreSQL 7.1 and above.
> To install the module, move this directory to the "contrib" directory of
> your
> PostgreSQL source installation. Alternately, edit the "top_buildir" in
> the
> Makefile and point it at your PostgreSQL source tree. You must have a
> PostgreSQL source tree, and you must have run succesfully built and
> installed
> it for this to work.
> Hope this helps someone.
> Peter
> postgis-users mailing list
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
