FW: [postgis-users] FW: [Psycopg] RELEASE: GeoTypes-0.2.0a1
Norman Vine
nhv at cape.com
Thu Sep 25 03:26:00 PDT 2003
Richard
I have been forwarding your posts to the PostGIS list so that the
developers can participate. Perhaps you should just cross-post
there, so I don't have to do this manually :-)
Cheers
Norman
> -----Original Message-----
> From: Richard Taylor [mailto:r.taylor at eris.qinetiq.com]
> Sent: Thursday, September 25, 2003 3:35 AM
> To: nhv at cape.com; psycopg at lamu.initd.org
> Subject: Re: FW: [postgis-users] FW: [Psycopg] RELEASE: GeoTypes-0.2.0a1
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On Thursday 25 September 2003 2:09 am, Norman Vine wrote:
> > > Yes - this is probably the best thing to do. The OGC function
> > > GetGeometryType() basically tells you what type the actual geometry is.
> > > So, a MULTIPOLYGON returns "MULTIPOLYGON".
> > > Also, I suggest you plan for using WKB instead of WKT because its much
> > > more efficient (space wise), easier to parse, and you dont lose any
> > > precision in your coordinates.
> I will have to look into WKB before I go any further. I don't know what the
> issues are here. I guess I need to use a binary cursor in Psycopg (I have not
> used these before) and then work out how to parse the result in python. I
> will also have to read the WKB docs to understand it better.
> Would using the GetGeometryType() function require two trips to the database
> for each return? e.g.
> <list of geometry objects> = select geo_obj from geo_table;
> for each geometry_object
> geometry_sub_type = select GetGeometryType(geometry_object)
> I was trying to avoid this. It is possible to avoid it with the WKT format
> because the real sub type of the object is encoded in the format is this true
> of the WKB format? (I will read it anyway).
> Regards
> Richard
> QinetiQ
> B009 Woodward Building
> St. Andrews Road
> Malvern
> Worcs WR14 3PS
> Jabber: RichardTaylor at jabber.org
> PGPKey: http://search.keyserver.net:11371/pks/lookup?op=get&search=0xA7DA9FD9
> Key fingerprint = D051 A121 E7C3 485F 3C0E 1593 ED9E D868 A7DA 9FD9
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.1 (GNU/Linux)
> iD8DBQE/cpq07Z7YaKfan9kRAkVCAJ0RFZeCBMu4S+YbtA0GeENZnom+RQCeLVPW
> K1I0bunYOWExH7Srsh0PS0w=
> =VSe9
> -----END PGP SIGNATURE-----
