FW: [postgis-users] FW: [Psycopg] RELEASE: GeoTypes-0.2.0a1
David Blasby dblasby at refractions.net
Thu Sep 25 09:13:51 PDT 2003
>>I will have to look into WKB before I go any further. I don't know what the
>>issues are here. I guess I need to use a binary cursor in Psycopg (I have not
>>used these before) and then work out how to parse the result in python. I
>>will also have to read the WKB docs to understand it better.
You can either make a binary cursor, or you can cheat and just use a
normal query.  If you use the normal query, you'll get your WKB in hex
form.  Ie. "FF00FF"  - you'll have to translate this to a byte array and
then treat it as normal WKB.  "FF00FF" would be 255,0,255.
>>Would using the GetGeometryType()  function require two trips to the database
>>for each return? e.g.
>>	<list of geometry objects> = select geo_obj from geo_table;
>>	for each geometry_object
>>		geometry_sub_type = select GetGeometryType(geometry_object)
>>I was trying to avoid this. It is possible to avoid it with the WKT format
>>because the real sub type of the object is encoded in the format is this true
>>of the WKB format? (I will read it anyway).
Actually, the GetGeometryType() is easy to determine by either looking
at the WKT or WKB.
For WKT - just look at the first word in the text.  ie. "POLYGON"
FOR WKB - the same code is given in the first few bytes of the WKT.
dave
ps. The OGC SF SQL spec has definitions of WKT and WKB:
http://www.opengis.org/techno/specs/99-049.pdf
