[postgis-users] postgis support for 7.4 betas
Jeff Hoffmann
jeff at propertykey.com
Sun Sep 28 08:26:49 PDT 2003
David Blasby wrote:
> Jeff Hoffmann wrote:
> I did basically the same thing (and modified another function).
Thanks for confirming that for me, although I've run into another
problem. I had some experience mucking around with cost estimates
several versions ago it wasn't so daunting to dig around in the source
and try to fix it. The new problem, I'm not so sure where the problem
lies. I'm trying to use PostgreSQL 7.4b3/PostGIS 0.7.5(patched with new
estimate code you gave me) along with MapServer 4.0. Something has
broken the binary cursors that MapServer uses when it queries the
database for a layer. Here's the error that I get:
msPOSTGISLayerWhichShapes(): Query error. Error executing POSTGIS SQL
statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
county WHERE the_geom && setSRID('BOX3D(-82.2975991147483
27.9197193376958,-82.2935143751022 27.9224420799425)'::BOX3D,
find_srid('','county','the_geom') )
-ERROR: no binary output function available for type wkb
When I execute the query outside of the cursor it seems to work & when I
do it with a standard (non-binary) cursor, it apparently works. Only in
the binary cursor do I get the "no binary output function available..."
error. Do you have any ideas why this would be happening or even some
clues to searching out what has changed to cause this problem in 7.4?
Jeff Hoffmann
PropertyKey.com
