[postgis-users] postgis support for 7.4 betas
Jeff Hoffmann
jeff at propertykey.com
Mon Sep 29 06:14:25 PDT 2003
Jeff Hoffmann wrote:
> I'm trying to use PostgreSQL 7.4b3/PostGIS 0.7.5(patched with new
> estimate code you gave me) along with MapServer 4.0. Something has
> broken the binary cursors that MapServer uses when it queries the
> database for a layer. Here's the error that I get:
> msPOSTGISLayerWhichShapes(): Query error. Error executing POSTGIS SQL
> statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
> county WHERE the_geom && setSRID('BOX3D(-82.2975991147483
> 27.9197193376958,-82.2935143751022 27.9224420799425)'::BOX3D,
> find_srid('','county','the_geom') )
> -ERROR: no binary output function available for type wkb
> When I execute the query outside of the cursor it seems to work & when I
> do it with a standard (non-binary) cursor, it apparently works. Only in
> the binary cursor do I get the "no binary output function available..."
> error. Do you have any ideas why this would be happening or even some
> clues to searching out what has changed to cause this problem in 7.4?
Just to follow up, I did some digging around & ended up changing the
function definition for "asbinary(geometry, text)" to return type
"bytea" instead of "wkb" & that seemed to solve the problem, although I
don't know if it's going to break anything as a result. I'm guessing
that the bytea(wkb) function was there for just this case & was being
used in 7.3 but isn't being used for some reason with 7.4. I know next
to nothing about the typecasting, though, so it's just a guess.
Jeff Hoffmann
PropertyKey.com
