[postgis-users] postgis support for 7.4 betas
David Blasby
dblasby at refractions.net
Mon Sep 29 13:44:57 PDT 2003
> Actually, it should be "send=bytea" instead of "send=WKBtoBYTEA", but
> that does the trick when I revert back to the original asbinary function
> definition. Besides adding that line, the only other change I made was
> that I had to move the function definition of bytea to right before the
> "CREATE TYPE" command so it was available for the command.
Hummm - you're right, its supposed to be "send=bytea". WKBtoBYTEA is
the actual function that bytea(geometry) calls. Ooops.
dave
