[GENERAL] [postgis-users] Union as an aggregate
David Blasby dblasby at refractions.net
Tue Sep 30 16:25:44 PDT 2003
strk,
I've been looking for the source of the memory leak.  I was able to
reproduce "the problem" on my Linux machine.
I couldnt find any reason for a leak.  I had orginally thought that the
POSTGIS->GEOS or GEOS->POSTGIS converters might be leaking.
My first check was on the POSTGIS->GEOS converter.
I've attached a simple little .cpp program that creates polygons the
same way as the postgis code does.  I checked with valgrind, and it
leaks a constant amount of memory (probably static structures inside
geos).
So, that indicates its not the POSTGIS->GEOS convertor.  I also looked
at the postgis geomUnion() functions.  I dont think there's a leak there.
I'm looking at the GEOS->POSTGIS converter and I think I might have
found a problem.
dave
ps. how do you pronounce "strk"?  stUrk? stIrk?
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030930/1c5e47a9/attachment.ksh>
