[postgis-users] pgsql2shp/shp2pgsql and php
Tyler Mitchell TMitchell at lignum.com
Thu Apr 1 09:01:58 PST 2004
Did you try running the script manually from a command line first to make
sure it works?  Or are you running this through a web server who may not
have permissions to execute pgsql2shp or write the output shapefile.  I
assume you want to have a path to the pgsql2shp as well, though it appears
that it is running.
I would also recommend using ogr2ogr (from
http://gdal.velocet.ca/projects/opengis/) which should allow you to
convert directly from one postgis database to another (and I don't think
it adds an extra GID column ;).
Tyler
postgis-users-bounces at postgis.refractions.net wrote on 04/01/2004 07:50:37
AM:
> thanks david!
> i tried this:
> <?php
> $ret = shell_exec ("pgsql2shp -f <filename> -u <user> -g <geom_column>
-h
> <host> <dbname> <tablename> 2>&1");
> echo $ret;
> and received the error message: could not create dbf file
> when running pgsql2shp from command line everything works fine but not
from
> within the php-script! i also tried the .sh-thing but the same result!
any
> ideas???
> stefan
> you should use from php
> shell_exec("shp2pgsql ...");
> or
> shell_exec(pgsql2shp ..."),
> or writing a shell (foo.sh) from php-script with in
> foo.sh:
> shp2pgsql ....
> pgsql2shp ...
> and do shell_exec(foo.sh)
> I think this method could be improved :)
> +++ NEU bei GMX und erstmalig in Deutschland: TÜV-geprüfter Virenschutz
> 100% Virenerkennung nach Wildlist. Infos: http://www.gmx.net/virenschutz
> postgis-users mailing list
