[postgis-users] INTERSECT TWO TABLES
strk strk at keybit.net
Sun Apr 4 07:43:21 PDT 2004
On Sun, Apr 04, 2004 at 04:33:53PM +0200, Erwan Bocher wrote:
> Hi,
> I'm novice in POSTGIS. I'd like to intersect two tables witch contains polygons. The query must return another table with all polygon intersection.
> I've used this query :
> select intersection((select the_geom from parcelle1),(select the_geom from parcelle2)) into tabintersection;
SELECT intersection(p1.the_geom, p2.the_geom) INTO tabintersection
	FROM  parcelle1 p1, parcelle2 p2 WHERE p1.oid != p2.oid;
Note that the WHERE clause (missing on your query) is needed to
avoid useles intersection of geometris with themselves (if you need
that omit the WHERE clause).
--strk;
> but return error "more than one row returned by a subquery used as an expression"
> Could you help me ?
> Thanks
> Erwan
> postgis-users mailing list
