[postgis-users] INTERSECT TWO TABLES
Erwan Bocher
erwan.bocher at wanadoo.fr
Sun Apr 4 07:33:53 PDT 2004
I'm novice in POSTGIS. I'd like to intersect two tables witch contains polygons. The query must return another table with all polygon intersection.
I've used this query :
select intersection((select the_geom from parcelle1),(select the_geom from parcelle2)) into tabintersection;
but return error "more than one row returned by a subquery used as an expression"
Could you help me ?
Thanks
Erwan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040404/ff856fae/attachment.html>
