[postgis-users] Database initialisation
Tyler Mitchell
TMitchell at lignum.com
Mon Apr 12 15:17:41 PDT 2004
Good challenging opportunity for you :)
Install the old version of the database (and postgis, etc.) as per normal,
on a local copy of cygwin (i.e. that you control :). Then copy your data
folder over to your setup and start postgresql using that data folder.
Then do a dump of the database (ask again if you need help with that) to a
file. Don't try to restart your broken db, but initialize it, create a
database and load the dump file into the database. Enjoy. pgadmin may
have some tools to help go from 7.3 -> 7.4.1 directly rather than to file.
Tyler
postgis-users-bounces at postgis.refractions.net wrote on 04/04/2004 01:58:51
PM:
> Hello
> Someone has upgraded my postgres database on cygwin. The result is that
> my database won't start.
> FATAL: database files are incompatible with server
> DETAIL: The data directory was initialized by PostgreSQL version 7.3,
> which is
> not compatible with this version 7.4.1.
> Any idea of a quick, easy fix ?
> Thanks
> Chris
> postgis-users mailing list
