[postgis-users] postgres issue solved.
strk strk at keybit.net
Wed Apr 7 04:53:09 PDT 2004
On Wed, Apr 07, 2004 at 07:37:57AM -0400, dkittler at customerportfolios.com wrote:
> i looked at the make file and it appeared to be trying to select the
> correct version for postgresql but was unable to and perhaps defaulted
> to a prevoius version of 7.2 (i am running 7.4.2). i commented out this
> selection process and kept the USE_VERSION=74 and it worked.
The detector needs source tree of the installed postgresql.
By default it looks for it in ../../
If this is not the case you can override that path setting
the environmental variable PGSQL_SRC
It that still does not work, please report it as a bug
(consider using http://postgis.refractions.net/bugs/)
--strk;
> after reading the docs at http://www.postgis.com/docs/x83.html#AEN158 it
> became all too clear what was happening.
> thanks
> postgis-users mailing list
