[postgis-users] Which SRID to choose?
Markus Schaber
schabios at logi-track.com
Thu Apr 8 08:22:23 PDT 2004
On Thu, 25 Mar 2004 10:09:47 +0000
Homme Zwaagstra <hrz at geodata.soton.ac.uk> wrote:
> Your GPS receivers are likely to return coordinates in the WGS 1984
> system. The EPSG (http://www.epsg.org/) code for this is 4326. All
> srids currently appear to be the same as the EPSG code in the
> spatial_ref_sys table:
> select srid,auth_srid from spatial_ref_sys where srid != auth_srid;
> I can't comment much on your shapefile data except that shapefiles
> don't contain coordinate system information. You therefore have to
> find this out from associated metadata or your data supplier. If this
> doesn't reveal a specific EPSG code then some judicial searching of
> the spatial_ref_sys table (based on the coordinate system parameters
> you have otherwise found) should be fruitful.
We learned that our shapefiles are in in WGS 1984, too.
While searching for the DE_DHDN / GK_3 System that one of our customers
used I stumbled over the following problem:
There seems to be some difference between the EPSG codes in PostGIS and
the actual EPSG data - when I look for the "Deutsches
Einheitsdreiecksnetz" in Postgis, I get the SRIDs/EPSG-IDs 31491 to
31495, while the current EPSG database defines 31461 to 31469. Most of
the other reference systems seem to match.
Did I compare the wrong columns, or where is my error?
Happy Easter,
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
