[postgis-users] problem creating tables with geometry column
Wood Brent
pcreso at pcreso.com
Thu Apr 8 20:10:59 PDT 2004
This is partly a QGIS issue, but it relates to the underlyingPosGIS database.
I have imported a shapefile of elevation contours (table called contours).
This works fine, and has an entry in the geometry_columns table.
I then create a subset of the table,
select * into cont100 from contour where elevation = 100;
This creates (or seems to) a table with the appropriate subset of data. I can
query it & all seems fine.
Trying to display the new table in QGIS fails, as the new table is not loaded
into the geometry_columns table, which is apparently where QGIS builds it's
pick list of spatial tables to plot from.
I tried the addgeometrycolumn function, but this failed, as the new table
already had one.
Is there any way of updating the geometry_columns table with the appropriate
values for a table created by a select such as I used above?
Thanks,
Brent Wood
