[postgis-users] /usr/src/configure
Changqing Zhou
czhou at cs.umn.edu
Fri Apr 9 20:57:03 PDT 2004
I recently downloaded postgresql and postgis. When I was trying to run
./configure, I got errors at the bottom of the email.
Please help.
Thanks,
Changqing
***************************************** Instructions from web site.
Move the tar file to the 'contrib' directory of you PostgreSQL source tree
(e.g. "C:\cygwin\src\postgresql-7.4-1\contrib"), and de-compress it.
cd /usr/src/postgresql-7.4-1
cd contrib
tar xvzf postgis-0.8.0.tar.gz
Change directories to the root of the PostgreSQL source tree:
cd ../..
Use the following configure arguments to configure the master makefile
correctly, then make, but DON'T make install
./configure --enable-multibyte --with-CXX --prefix=/usr --sysconfdir=/etc
--docdir=/usr/doc/postgresql-$version
make
$ pwd
/usr/src
czhou at CONSTITUTION /usr/src
$ ls
gcc-3.3.1-3 gcc-ada-3.3.1-3.README gcc-java-3.3.1-3.README
gcc-3.3.1-3.README gcc-g++-3.3.1-3.README gcc-objc-3.3.1-3.README
gcc-3.3.1-3.patch gcc-g77-3.3.1-3.README postgresql-7.4-1
gcc-3.3.1-3.sh gcc-gpc-3.3.1-3.README
$ ./configure
bash: ./configure: No such file or directory
