[postgis-users] /usr/src/configure
Pericles S. Nacionales
nacional at cbs.umn.edu
Fri Apr 9 22:14:14 PDT 2004
Changqing,
Greetings! It looks like you went one directory too far. You'll need
to be in /usr/src/postgresql-7.4-1 to run configure (so you really only
needed to cd ..). I hope it helps.
-Perry
On Fri, 2004-04-09 at 22:57, Changqing Zhou wrote:
> Hi,
> I recently downloaded postgresql and postgis. When I was trying to run
> ./configure, I got errors at the bottom of the email.
> Please help.
> Thanks,
> Changqing
> ***************************************** Instructions from web site.
> Move the tar file to the 'contrib' directory of you PostgreSQL source tree
> (e.g. "C:\cygwin\src\postgresql-7.4-1\contrib"), and de-compress it.
> cd /usr/src/postgresql-7.4-1
> cd contrib
> tar xvzf postgis-0.8.0.tar.gz
> Change directories to the root of the PostgreSQL source tree:
> cd ../..
> Use the following configure arguments to configure the master makefile
> correctly, then make, but DON'T make install
> ./configure --enable-multibyte --with-CXX --prefix=/usr --sysconfdir=/etc
> --docdir=/usr/doc/postgresql-$version
> make
> $ pwd
> /usr/src
> czhou at CONSTITUTION /usr/src
> $ ls
> gcc-3.3.1-3 gcc-ada-3.3.1-3.README gcc-java-3.3.1-3.README
> gcc-3.3.1-3.README gcc-g++-3.3.1-3.README gcc-objc-3.3.1-3.README
> gcc-3.3.1-3.patch gcc-g77-3.3.1-3.README postgresql-7.4-1
> gcc-3.3.1-3.sh gcc-gpc-3.3.1-3.README
> $ ./configure
> bash: ./configure: No such file or directory
> postgis-users mailing list
"He's no geek.His tan's too good." -Benjamin Choate
