[postgis-users] /usr/src/configure
Changqing Zhou czhou at cs.umn.edu
Sat Apr 10 06:30:49 PDT 2004
Hi Perry,
Thanks for your response. There is no "configure" in
/usr/src/postgresql-7.4-1 either. see the script below.
czhou at CONSTITUTION /usr/src/postgresql-7.4-1
$ pwd
$ ls
contrib
$ ./configure
bash: ./configure: No such file or directory
On Sat, 10 Apr 2004, Pericles S. Nacionales wrote:
> Changqing,
> Greetings!  It looks like you went one directory too far.  You'll need
> to be in /usr/src/postgresql-7.4-1 to run configure (so you really only
> needed to cd ..).  I hope it helps.
> -Perry
> On Fri, 2004-04-09 at 22:57, Changqing Zhou wrote:
> > Hi,
> > I recently downloaded postgresql and postgis. When I was trying to run
> > ./configure, I got errors at the bottom of the email.
> > Please help.
> > Thanks,
> > Changqing
> > ***************************************** Instructions from web site.
> > Move the tar file to the 'contrib' directory of you PostgreSQL source tree
> > (e.g. "C:\cygwin\src\postgresql-7.4-1\contrib"), and de-compress it.
> > cd /usr/src/postgresql-7.4-1
> > cd contrib
> > tar xvzf postgis-0.8.0.tar.gz
> > Change directories to the root of the PostgreSQL source tree:
> > cd ../..
> > Use the following configure arguments to configure the master makefile
> > correctly, then make, but DON'T make install
> > ./configure --enable-multibyte --with-CXX --prefix=/usr --sysconfdir=/etc
> > --docdir=/usr/doc/postgresql-$version
> > make
> > $ pwd
> > /usr/src
> > $ ls
> > gcc-3.3.1-3         gcc-ada-3.3.1-3.README  gcc-java-3.3.1-3.README
> > gcc-3.3.1-3.README  gcc-g++-3.3.1-3.README  gcc-objc-3.3.1-3.README
> > gcc-3.3.1-3.patch   gcc-g77-3.3.1-3.README  postgresql-7.4-1
> > gcc-3.3.1-3.sh      gcc-gpc-3.3.1-3.README
> > $ ./configure
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> "He's no geek.His tan's too good." -Benjamin Choate
