[postgis-users] GeometryN() function - bug
David Blasby
dblasby at refractions.net
Tue Apr 13 09:50:49 PDT 2004
christopher.faulkner at ntlworld.com wrote:
> Thanks for the quick advice.
>>You must be looking at old documentation - I updated it
>>when I fixed this.
>>The correct behavior is "1" being the 1st geometry in a
>>collection.
> For documentation, I was looking on the live website - this still refers to a zero based index. http://postgis.refractions.net/docs/c671.html#AEN674
> I just checked in the c671.html page in the postgis 0.8.1 tarfile and it has the same information. Perhaps this should also be in the "changes" file.
Okay - I fixed it and re-commited the documentation. Sorry about that -
I could have sworn that I had updated that.
There was a discussion on this topic a little while ago. If you want
your postgis installation to have "geometryN(...)" be 0-based (like it
used to be) instead of 1-based (like it is now), you can change a line
in postgis_fn.c (around line 90):
#define NfunctionFirstPoint 1
// if you use #define NfunctionFirstPoint 0, you get 0-based indexing
(this is what programmers want)::
// pointN(<linestring>, 0) is the 1st point, and pointN(<linestring>,
1) is the second point.
// if you use #define NfunctionFirstPoint 1, you get 1-based indexing
(which seems to be what the spec wants)::
// pointN(<linestring>, 1) is the 1st point, and pointN(<linestring>,
2) is the second point.
dave
