[postgis-users] Multiuser system question
Jan Hartmann
j.l.h.hartmann at uva.nl
Wed Apr 14 03:14:38 PDT 2004
Jan Hartmann wrote:
>> Alexander Pucher wrote:
>>> I'm setting up a multiuser system with PostGIS and UMN MapServer.
>>> When the user starts the system, a unique id is assigned to the session.
>>> I offer the user a selection of "default" geometry sets to work with.
>>> During the session, the user can buffer geometries, which are stored
>>> as new geometry tables in the system. To keep track of the various
>>> users/tables, I have a kind of "lookup table", referencing the unique
>>> id with the geometry tables.
>>> The question is a rather pragmatic one. Should I set up one
>>> lookup-table and store all default tables along with all table
>>> references that all users create, or create a seperate lookup table
>>> for every session that is started? So consider 500 people with each
>>> more then 20 geometry tables working on the system the same time.
>>> What is more performant: all users working on one big table or
>>> working on several smaller ones?
On second thoughts: if your user group is small and you know them all
beforehand, you can set up a schema for each user and drop all tables
for that user in his schema. For classroom situations this works quite well.
Jan
