[postgis-users] createlang plpgsql mydatabase
Robert Aldridge bamarob55 at yahoo.com
Fri Apr 16 08:09:57 PDT 2004
Thanks for the quick reply.  That very well could be
the problem, I suppose.  In my excitement to get
everything set up on this new laptop, I could have
messed something up.  I went through several
iterations of trying to install postgresql from .deb
files without success.  I finally ended up installing
postgresql and postgis from source.  Everything seemed
to install correctly.
I gave up on using createlang and used the
instructions from the PostgreSQL Documentation on
'CREATE LANGUAGE' to manually create the language.
Again, everyting seemed to go fine with no errors.
However, when I try to run 'psql -f postgis -d
mydatabase', I get:
psql:postgis.sql:44: NOTICE: type "histogram2d" is not
yet defined
DETAIL:  Creating a shell type definition.
psql:postgis.sql:44: ERROR: could not access file
"$libdir/libpostgis.so.0.8": No such file or directory
This is followed by lots of 'ERROR: current trasaction
is aborted, commands ignored until end of transaction
block' errors.
Is this install fixable, or do I need to try starting
over from scratch?
Thanks,
Robert Aldridge
Could you have different versions of createlang and
psql? Because they
both use libpq, if they are compiled at the same time,
with the same
configuration, they generally work identically (same
libpq defaults),
so the problem you are getting should not occur.
On Friday, April 16, 2004, at 07:30 AM, Robert
Aldridge wrote:
> I'm having problems with the createlang command
when,
> as the postgres user, I run:
> I get:
> createlang: could not connect to database
mydatabase:
> could not connect to server: No such file or
directory
>      Is the server running locally and accepting
>      connections on Unix domain socket
> "/tmp/.s.PGSQL.5432"?
> However, if I run:
> psql -d mydatabase
> It connects to the database fine.  I get:
> mydatabase=#
> Any ideas why createlang isn't working?  Do I have
to
> install the language before I can create it on a
> database?
> Thanks for any input you can provide,
> Robert Aldridge
__________________________________
Do you Yahoo!?
Yahoo! Tax Center - File online by April 15th
http://taxes.yahoo.com/filing.html
