[postgis-users] Lines inside Polys
Wood Brent
pcreso at pcreso.com
Sun Apr 18 17:22:25 PDT 2004
--- David Mitchell <david.mitchell at telogis.com> wrote:
> Hi,
> I have a whole bunch of lines and each line falls entirely within zero
> or one of a pile of polygons. The line might touch another polygon (for
> instance, if two polygons share an edge and the line goes right to the
> edge of its parent polygon). None of the polygons overlap. What I want
> to find out is which polygon each line falls within. Currently I am
> doing this:
Um, without thinking too much about it, the following spring to mind:
iterate through each line with a "limit 1" might prove faster?
Select the midpoint of each line & do a point check instead, as this may be
faster?
I assume you have created a GIST index on both lines and polygons?
Brent Wood
