[postgis-users] pgsql2shp errors out after upgrading to 0.8.1
markc at weaponeer.com markc at weaponeer.com
Sun Apr 18 20:04:57 PDT 2004
Hello,
  I've used pgsql2shp many times with this database, after
upgrading to 0.8.1 I am getting an odd cast error.
  Postgres is 7.4.2, using bison-1.875 (the problem ??),
PostGIS is using gdal-1.2.0 (proj-4.4.7).
  Also if I import a .shp of this made in 1-2004 (which
seems to work) it dies with another syntax error.
  I can send a dump of this db, as it's reasonably small.
 Thanks,
  Mark
markc at linux:~/qgis-0.1> pgsql2shp -b gis_main us_plant_rad_x
Initializing... Done.
ERROR:  syntax error at or near ""::text,"" at character
1121
markc at linux:~/qgis-0.1> psql -d gis_main
Welcome to psql 7.4.2, the PostgreSQL interactive terminal.
Type:  \copyright for distribution terms
       \h for help with SQL commands
       \? for help on internal slash commands
       \g or terminate with semicolon to execute query
       \q to quit
gis_main=# select * from us_plant_rad_x;
gis_main=#
gis_main=# select version();
                                       version
 PostgreSQL 7.4.2 on i686-pc-linux-gnu, compiled by GCC gcc
(GCC) 3.3.1 (SuSE Linux)
(1 row)
